Additional 0.01mm Grid Step?
Chris56000
Beitrag von Chris56000 »
. . .Any chance of adding a 0.01mm or User Defined grid step in future versions of sPlan?
. . .This would be very useful for designing Veroboard Layouts exactly like those printed in the Construction Magazines!
. . .At present I have to place everything on a 2.5 mm grid multiple and then upscale the whole design by the ratio 2.54/2.50 which introduces many assorted errors!
Chris Williams
United Kingdom
Re: Additional 0.01mm Grid Step?
Unfortunately, a finer grid is currently not possible for technical reasons. Keep in mind that sPlan was developed for creating circuit diagrams.
Perhaps you can draw in a 12.7 mm grid. At the end you can scale down to 20%.
You can also set the scale to 1mm = 0.2mm in the page properties, then you will see the original size values ​​on the ruler etc.
