function 03 holding register read problem
mert
Beitrag von mert »
I read Data coming from PLC
with function 03 Holding registers
When I look at it from PLC, it says 235
but when reading with Profilab, i read the same value 355. my operating system win7 32bit.
Müllmann
Re: function 03 holding register read problem
Beitrag von Müllmann »
Depend on the first number 0 or 1 of beginning of holding registers you use the wrong register ? Try the register n-1 and n+1 of actual number n and compare the results.
mert
Beitrag von mert »
plc modbus adress table
read holding register and comport settings
Did you follow "Müllmann"s advice? Addresses may be "1"-based or "0"-based unfortunately, which quite often leads to confusion. Latest update installed?
Please try 4156 and 4158 and then come back with your report.
mert
Beitrag von mert »
Update 22.01.2020 The problem started when I installed it.
then the problem was solved when installing Update 05.02.2020
05.02.2020 update, this work has done a work, I think you need it.
Thanks for your feedback.
Zurück zu „Thema Modbus“
