Kommt Sprint Layout 7.0 ???
Sonny1983
Beitrag von Sonny1983 »
mich würde interessieren ob an der nächsten Version von Sprint Layout gearbeitet wird, und ob schon grob geschätzt werden kann, wann diese erscheinen wird?
Eine frohe Adventszeit wünscht
Simon Troschke
Re: Kommt Sprint Layout 7.0 ???
Da gibt es noch keine Planung. In 2020 nicht zu erwarten.
burhan
Beitrag von burhan »
Update for Rounded tracks and Text full UT8 support features for version 6 would be great..
Sonny1983
Gibt es evtl. schon Pläne v7 zu produzieren? Es sind ja durchaus einige Ideen und Vorschläge von den Usern vorhanden :D
Konkrete Pläne oder Planungen gibt es hier noch nicht.
Aber das ist auf jeden Fall eines unserer nächsten Projekte.
G4AON
Beitrag von G4AON »
It is some time since the last update to Sprint Layout and there have been several “easy” updates that users request.
Being able to import logos to print on the silk screen layer should be straightforward. Similarly, being able to pick different fonts for text would be nice.
Being able to use isolated pads in areas that are not ground (used for fixing bolts).
When changing the grid, components previously placed do not snap to the new grid when moved. Can this be fixed?
Thanks
Dave
Thanks for your suggestions.
This is not a bug that needs to be fixed. When moving, the elements move in increments of the currently selected grid. They do not automatically snap to the new grid as this would cause unwanted movement. You can of course select the elements and invoke the Snap to Grid feature if you want.
Chris56000
Beitrag von Chris56000 »
Hi!
. . .I would like the facility to choose TTF as well as I have several British Stencil Fonts that work out all right on PCBs I have had made with "Number One System's Easy–PC" - Easy PC does not lend itself to tracing a design from magazine artwork like you can with Sprint Layout, I could then use "Microgramma" for the Component Lettering if you implemented this!
Chris Williams
(Walsall, UK)
