example 2 tablo demo excel auto kayıt
mert
Beitrag von mert »
I want to record data automatically as excel as example 2
Re: example 2 tablo demo excel auto kayıt
Beitrag von Mike D »
then do it
mert
Beitrag von mert »
I'm printing the data that comes on the table to the table demo.
I choose ms-excel on the front of the table
When I say save excel at the front side of the file directly into excel file.
Müllmann
Beitrag von Müllmann »
Sorry, but i don't see any question in your post.
If you have problems with the table, then explain with more details.
If the hotkey =XLS has no function, then try the hotkey =CPY.
This will copy the table to the clipboard, then start MS Excel or OpenOffice Calc
and use paste.
mert
Beitrag von mert »
attached to the sample work in the compilation_datarecord run each instance when
we get the data into the folder with the .TXT extension,
I can not save as .txt not excel here
how can I do it.
datarecord.prj
(1.44 KiB) 854-mal heruntergeladen
datarecord.prj
(1.39 KiB) 824-mal heruntergeladen
Müllmann
Why do you use the data recorder MWR in addition to the table TAB ?
Look to the properties of the table TAB, there are functions to create
Word or Excel files. In addition you can define hotkeys to start Excel
after pushing a button or to copy in clipboard to paste in other
applications. See appended example.
datarecord3.prj
(2.34 KiB) 834-mal heruntergeladen
mert
Beitrag von mert »
hello by.Müllmann
I looked at the sample you sent the sample excell key to
save the data is set to come from the plc I want to save a
record directly with the trigger without opening excell any key on the front of the key is it possible?
Müllmann
Sorry, i thougt, there is a way, but it seems not to be or i can't find it.
Therefore you only can create txt files with the data recorder MWR directly
and then you can convert it to excel. Maybe you find a function in excel
to import the txt file automatically, i don't know.
