Set list question
Set list question
Chip
Anmeldungsdatum: 18.08.2006
Verfasst am: 25.08.2006 10:02 Titel: Set list question
Hello,
I have a question about the set list component for the frontpanel settings.
How do I use this component with a self chosen directory to store the settings in? When I store the set files "loose" in the examplesdirectory everything works fine, but when i want to use a directory i have made myself to store the files in I can't seem to make it work. How do I make the set list component or the project "see" my self chosen directory with the set files in it?
thanks, "Chip"
Verfasst am: 25.08.2006 14:47 Titel: Set list
Hello Chip,
the set list collects all available set files that are stored in the projects directory (together with the ".prj") . It does not handle file allocation table for other locations, just to keep it simple. We had to mention this point in the help file. Sorry.
Chip
Verfasst am: 26.08.2006 09:32 Titel:
Thanks for your reply Abacom! This was also the solution/answer to my question, I can see what I am doing wrong now!
I quite often put projects in the same directory, which gives a problem when you use the set files because each project with a set list component can then "see" the set files not just the project you have stored them with.
So the solution for me is to make sure I store each project in it's own directory along with it's set files.
"Chip"
