Quancom: input module
Philip
Beitrag von Philip »
Hello,
When i use the Quancom driver i cannot receive rs232 strings in profilab on the other com ports.
The Qlib DLL alsso connects to a com port,when i disable this com port then i can read the other com ports with Profilab.
When i use another program like hyperterminal i have no problem using a com port together with the Quancom module.
The problem is only with receiving strings on the other com ports sending strings works ok.
Does any one have a idea about the problem?
grtz
Philip
Re: Quancom input module
Beitrag von compander »
Hallo Philip.
What is the Quancom Device?
C :shock: mpander.
Philip
Hello Compander
It is the Seropto64 in,a serial input module with 64 inputs,it uses the Qlib DLL to communicate with profilab.profilab doesnt acces the com port of this module directly.
I noticed anaother post about the rs232 input used with the busy and pon connected to the clock.I use the same to read the rs232 of the other com ports,i will try to use a clock signal instead of the busy/pon method to see if this will solve the problem.
grtz
Philip
Zurück zu „Geräte: Quancom“
