If you place a pad on the "automatic-Ground plane" it will have a clearance to the groundplane.
- sl1.png (5.62 KiB) 6829 mal betrachtet
The width of this clearance can be set in the lower statusbar. You can change this value if nothing is selected, then it will be the new default value for all new elements. Or you can select a pad and then change this value only for this selected pad.
