String comparator ,problem
TOURNEUR
Beitrag von TOURNEUR »
Hello ,
I'm trying to built ,an automatic program in Prflab ,for a bluetooth module.
When the module acknowledge the good protocol of command, it transmit a string "OK"
I 'm arrived to display this string ,but not compare.
I used string comparator with OK in channel A ,and string from port com receive.
I am not arrive to detect this "OK" string
Thank for people ,who can help me
Here, pictures of my problem
Ascii display.PNG (1.3 KiB) 14661 mal betrachtet
String display.PNG (3.95 KiB) 14662 mal betrachtet
String comparator.PNG (14.17 KiB) 14650 mal betrachtet
Re: String comparator ,problem
Beitrag von IKT »
Hello TOURNEUR,
you might have to put a '$TRIM' in between the 'Selection' & the '$COMP' parts, as in the picture below. (removes any unwanted SPACES from String)
As an alternative check it out with a '$CONST' instead of 'Selection' ...
TOURNEUR
Good evening , IKT
Thank you for your help ,
I inserted this function between my Hex generator and comparator.
Without any success ...
I have put command on left and right, but nothing more .
ankerwolf
Beitrag von ankerwolf »
Hello,
may be that there are CR LF at the end of the string, coming form the device?
LG Wolfgang
Beitrag von Mike D »
Hei,
try $Position instead of $Comp, then leading or trailing unvisible chars dont bother.
Any number greater than zero means, that $S exist in $M.
If you position the cursor on a connection during the projekt is running, you can see the actual value of the singnal.
