Read Ascii File
emilio
Read Ascii File
Beitrag von emilio » Dienstag 27. Januar 2015, 14:40
Hello
In my application, I want to read an ascii file, I'm arriving to that, but i'dont understand how I can read a special line of this file and also if it's possible to do some calculations with this ascii file and to display this calculations ?
Re: Read Ascii File
Beitrag von IKT » Donnerstag 29. Januar 2015, 01:29
emilio hat geschrieben:Hello
Since I don't fully understand your question, it is hard to answer:
with the "read line from file" component you can read any line from a text-file.
Index 0 = line 1
You might also want to check out the read CSV component.
Thereafter you can do whatever you like with the read information (like from any other source).
Re: Read Ascii File
Beitrag von abacom » Donnerstag 29. Januar 2015, 09:10
...see...
viewtopic.php?f=43&t=3642&hilit=sollwerte
...the solution is included in...
download/file.php?id=2038
