Ground plane connection to Ground
Beitrag von abacom » Donnerstag 25. September 2008, 14:07
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 14.06.2007 14:03 Titel: Ground plane connection to Ground
Dear Abacom.
Please inform me whether the following is good practice and if it will function,
I would like to select the ground plane on one ground pin in the header spaceing as zero to connect the plane to actual ground ,
Will this zero spacing between the pin and the ground plane cause an electrical connection this actively takeing the plain to ground.
is this an acceptable pratice to ground the ground plane in noise enviroments.
I am just not sure if this is the correct manner to do this
Thank you
Peter
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
Verfasst am: 15.06.2007 08:07 Titel:
You are absolutely right, doing it that way.
p.erasmus
Verfasst am: 15.06.2007 08:51 Titel:
Dear Abacom
Thank you for the answer.
Best regards
Peter
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
