Send receive uart
Send receive uart
Hello
In a realization ,I use a specific module from Parallax, the motor mind B.
The protocol is pretty simple ,and i started use RS232 hardware module from Profilab EX.
In first I used the octal receiver which not include any synchro separator in the setting parameter .
But to affine my project ,where I must receive multiple octets, I started use the string séparator with chain séparator ,to divide the multiple octets out.
But at this time ,the string separator wasn't realize any reception of my module.
I check ,n° of port ,baud flux ,which is the habitual error .
But I think the separator set in the parameter ,which is the unique difference with octet receiver ,is the cause of the non reception of my module .
I tested the string receiver without any separator in the setting ,in the emitter too .
But no chains flux appear again from my receiver .
There is only read possible with the octal receiver .
With a serial software spy ,I always see my response come after a request ,but never out of my rs232 string module from profilab expert .
I don't understand ...
- Emit receive UART3.PNG (90.97 KiB) 23867 mal betrachtet
- Emit receive UART2.PNG (108.93 KiB) 23866 mal betrachtet
- Emit receive UART.PNG (26.89 KiB) 23863 mal betrachtet
Re: Send receive uart problem
Hi
I am not sure if I understand you correctly however to receive strings(data) from the serial (UART) port you need a COM receive component which I do not see in your screen prints you posted
just a thought ,I use a Serial To USB converter chip and the COM components in PL4 works perfectly
Good luck
Good luck
Thanks for your reply Qmesar,
I thought ,my post too much detailed ,and could give some confusion in my help request.
I do not have problem in the communication with my external device .
I received correctly my frame byte with "recevoir octet" module like the picture "Emit receive UART2"
But when I use "COM" like in the picture "Emit receive UART3" nothing come from the module, but you can see with a spy uart software log in the picture "Emit receive UART" ,my external device send his reply correctly after a request ,without any separation bytes.
I set the com module without any separation byte ,but it don't reply .
Why the com module ,without separation byte ,not reply like "octet receiver " module ?
Hi
Unfortunately I do not know this component hope one of the experience users will /can help you
good luck
good luck
Not certain to understand the problem correctly ...
A simple COM send / receive String (base cirquit only) see below:
Thanks ,for your help IKT
But unfortunally ,it's doesn't work ...
I ask myself if string com ,recognize HEX format ,
When i use octet com ,everything coming into my com port appear on the virtual pin ,without any synchro bytes.
But the protocol which i use ,employ the HEX format .
With the string com ,I have ASCII to CHAR converter ,CHAR to ASCII converter , but hex is different to CHAR or ASCII .
It's my proper thinking ,but I can do an error ....
I don't know if COM value can receive directly hex format .
The synchro byte which give me problem too ,
With octet com, no synchro byte needed ...
Hi TOURNEUR,
can you please post the Manual of the device you are using?? A .pdf would be fine. Otherwise, a link to the Manual, on the Manufacturers web page.
Hello IKT,
This is a motor controler from Paralax, which the name is Motor Mind B.
I tested all the sub function excepted the "Read_pi command " ,which use scalar value ,which is too floating for me .
If you will want learn it ,here the documentation :
- Motor mind B.pdf
- (100.65 KiB) 1074-mal heruntergeladen
Hi TOURNEUR,
my conclusions, so far:
1) you can't use "String" to send, you'll have to use "Send-Byte(s)" or similar. (the same goes for receive ...)
2) PI in Manual refers to "Proportional Integral" Filter (not related to math. PI = 3.1415...)
3) you can use Byte(s) as decimal or hexadecimal (as you like, just: don't "mix" them).
Details of each command, are explained in detail, in the Manual.
Good luck.
Good luck.
Refer to protocol description in device manual.
You may take advantage of this...
viewtopic.php?f=53&t=4130
Hello ,
In first time ,i would send all my apologies ,at my late reply since the last post from the administrator .
To replies at this last post ,the module send/receive work perfectly at my request .
Directly in decimal format (easier to interpret during test )
I recopied the exemple fom the module request / response and modify it for my proper program .
And all work so fine !
Many thanks ,at the forum for your help !
