Hantek 6022BL USC Oscilloscope - DLL for ProfiLab
- Kontaktdaten:
Hello,
I bought an oscilloscope USB Oscilloscope Hantel 6022BL.
He wanted me to cooperate with PROFILAB Expert, but does not know how to program.
if someone could create a dll?
PLEASE
oryginal examples file for VB, VC, LabView:
https://drive.google.com/open?id=0B7JUH ... XRHT1puZVU
PLEASE
Re: Hantek 6022BL USC Oscilloscope - DLL for ProfiLab
before anything else: could you please provide the Manual (EN) here? (NOT Google etc.)
Because the provided Driver (Hantek) will probably do (if it is VCP = virtual COM Port).
- Kontaktdaten:
Im sorry for my english. This is all files for my oscilloscope.
this archive is on the google drive, because size its higher than 256kb. I can send to mail. Please help.
https://drive.google.com/open?id=0B7JUH ... TFNUDBfM00
There is insufficient information about the installed drivers, in the Manual ...
The Oscilloscope has to be connected to the PC before opening Device Manager.
Can you please post the output (Screen-Shot) of the Device Manager here?
Most likely the device can only be accessed with the manufactures DLL-API.
- Kontaktdaten:
This is a photo on driver for my hantek oscilloscope.
Detected as only hardware (not virtual com port)
how running example for Visual Basic, or Lab View ? (Examples sources)
- screen.PNG (35.2 KiB) 24382 mal betrachtet
BTW: You should "disable" the faulty PCI-Modem (or get it to work properly).
I'm not so certain about that, can you check (click the +) left of *Porty (COM i LPT)*, to see what's in there?Detected as only hardware (not virtual com port)
- Kontaktdaten:
This all my hardware.
BTW: My modem is disabled - thanks
- screen2.PNG (21.67 KiB) 24370 mal betrachtet
I think your VCP may be connected on COM1.
However, I don't understand the comment next to it???
Or are you saying your Laptop has a real, physical RS232 Port (HW)?
- Kontaktdaten:
My laptop its a very old.
Com1 port its a original physical hardware port.
OK. I get it. Just explain the reason, why you need/want to use it in PL.
There is a Software (from Hantek) provided for using the scope.
Coding DLL's is a Time consuming Task ...
Almost impossible without the HW (for Tests).
- Kontaktdaten:
I do not want to make trouble.
I would like to do Register voltage. Original software not supportet for voltage tools
Only Oscilloscope and logic analizer.
I don't understand (probably a language problem), Voltage can be seen on Oscilloscope (using the correct scaling, of course).
Or do you mean: record (Register) Voltage??
- Kontaktdaten:
Im sorry...
As for the recorder voltage
To do that, it's probably cheaper and easyer, to use a DMM (digital multi meter) connected to PL.
See Voltcraft VC Series, with RS232 Connector (straight connection to COM1, no Drivers needed), available: Conrad.
To see the complete List of compatible DMM's see HW-Compatibility-List (in PL, click ? in Menu) and use DMM as "Manufacturer" to shorten the List.
It seems, that you've got yourself the wrong Instrument, for the planned Task.
