Hantek 6022BL USC Oscilloscope - DLL for ProfiLab
lukg20
Beitrag von lukg20 »
Hello,
I bought an oscilloscope USB Oscilloscope Hantel 6022BL.
He wanted me to cooperate with PROFILAB Expert, but does not know how to program.
if someone could create a dll?
PLEASE
oryginal examples file for VB, VC, LabView:
https://drive.google.com/open?id=0B7JUH ... XRHT1puZVU
Re: Hantek 6022BL USC Oscilloscope - DLL for ProfiLab
Beitrag von IKT »
before anything else: could you please provide the Manual (EN) here? (NOT Google etc.)
Because the provided Driver (Hantek) will probably do (if it is VCP = virtual COM Port).
lukg20
Im sorry for my english. This is all files for my oscilloscope.
this archive is on the google drive, because size its higher than 256kb. I can send to mail. Please help.
https://drive.google.com/open?id=0B7JUH ... TFNUDBfM00
Beitrag von IKT »
There is insufficient information about the installed drivers, in the Manual ...
The Oscilloscope has to be connected to the PC before opening Device Manager.
Can you please post the output (Screen-Shot) of the Device Manager here?
Most likely the device can only be accessed with the manufactures DLL-API.
lukg20
This is a photo on driver for my hantek oscilloscope.
Detected as only hardware (not virtual com port)
how running example for Visual Basic, or Lab View ? (Examples sources)
Beitrag von IKT »
I'm not so certain about that, can you check (click the +) left of *Porty (COM i LPT)*, to see what's in there?
BTW: You should "disable" the faulty PCI-Modem (or get it to work properly).
lukg20
This all my hardware.
BTW: My modem is disabled - thanks ;)
Beitrag von IKT »
I think your VCP may be connected on COM1.
However, I don't understand the comment next to it???
Or are you saying your Laptop has a real, physical RS232 Port (HW)?
lukg20
My laptop its a very old.
Com1 port its a original physical hardware port.
Beitrag von IKT »
OK. I get it. Just explain the reason, why you need/want to use it in PL.
There is a Software (from Hantek) provided for using the scope.
Coding DLL's is a Time consuming Task ...
Almost impossible without the HW (for Tests).
lukg20
I do not want to make trouble.
I would like to do Register voltage. Original software not supportet for voltage tools :(
Only Oscilloscope and logic analizer.
Beitrag von IKT »
I don't understand (probably a language problem), Voltage can be seen on Oscilloscope (using the correct scaling, of course).
Or do you mean: record (Register) Voltage??
lukg20
Im sorry...
As for the recorder voltage
Beitrag von IKT »
To do that, it's probably cheaper and easyer, to use a DMM (digital multi meter) connected to PL.
See Voltcraft VC Series, with RS232 Connector (straight connection to COM1, no Drivers needed), available: Conrad.
To see the complete List of compatible DMM's see HW-Compatibility-List (in PL, click ? in Menu) and use DMM as "Manufacturer" to shorten the List.
It seems, that you've got yourself the wrong Instrument, for the planned Task.
Zurück zu „Haussteuerungen“
