A plugin for Sprint-Layout, Import footprint from Kicad/EasyEDA
cdhigh
Re: A plugin for Sprint-Layout, Import footprint from Kicad/EasyEDA
Beitrag von cdhigh » Freitag 19. August 2022, 15:34
I scaned the 3 qrcode images you generated, the results correct.
K-B-L
Beitrag von K-B-L » Freitag 19. August 2022, 15:57
but why it looks different?
my Iphone can only scan the black one. Not the QR in Sprint Layout
cdhigh
Beitrag von cdhigh » Freitag 19. August 2022, 16:45
The qrcode feature of IPhone camera is not very smart (less tolerance).
I tested with iPhone.
Found that iPhone can recognized both 2 images If I increased the grid size of Sprint-Layout to 5.08mm.
There are many parameters for QR code generation, and different parameters will produce different images, but all of them are valid.
For example, all of 4 images follows are generated from a same text string, but with the different error correction levels.
K-B-L
Beitrag von K-B-L » Freitag 19. August 2022, 17:04
ok thx for info
nounours18200
Beitrag von nounours18200 » Freitag 4. November 2022, 19:54
@cdhigh:
I will test the advanced features later, but for the time being I have just imported a few SMD footprints from Kicad, and your plugin is excellent !!
A must-have plugin: congratulations !!
CD32Freak
Beitrag von CD32Freak » Dienstag 21. November 2023, 20:01
Amazing plugin, you've implemented the features that were really missing in Sprint Layout! Thanks for sharing, cdhigh!
nounours18200
Beitrag von nounours18200 » Dienstag 18. Juni 2024, 17:40
This plugin is so amazing : it allows us to import any footprint from the huge Kicad librairy....
I have been using it since it has been released (v1.5.2), to import the "name of footprint.kicad_mod" files, from Kicad 6.0 , but I have recently tried to import a "kicad_mod" file from Kicad 8.0, and I have an error (impossible to parse ...).
Did I make a mistake, or do you also face problems by importing footprints from Kicad 8.0 ?
Thanks
burhan
Beitrag von burhan » Sonntag 23. Juni 2024, 16:03
nounours18200 hat geschrieben:
Thanks
Have you tried the latest version?
https://github.com/cdhigh/sprintFontRel ... v1.5.4.rar
https://github.com/cdhigh/sprintFontRelease/releases
nounours18200
Beitrag von nounours18200 » Samstag 29. Juni 2024, 10:28
Not yet, but I made a wrong manipulation, so the version 1.5.2. does work for importing the Footprints from Kicad 8.0.
What is the procedure for upgrading Sprinfont from version 1.5.2 to 1.5.4 ?
Thanks and congratulations again for this must have plugin !
cdhigh
Beitrag von cdhigh » Samstag 16. November 2024, 12:23
Released v1.6.
Added feature: inverted font background (negative font image).
https://github.com/cdhigh/sprintFontRel ... t_v1.6.rar
cdhigh
Beitrag von cdhigh » Montag 3. Februar 2025, 23:16
Released a new version v1.7
Added feature: Differential Pair Length Matching (serpentine trace)
burhan
Beitrag von burhan » Mittwoch 5. Februar 2025, 21:18
Thanks @cdhigh very good developments are happening.
nounours18200
Beitrag von nounours18200 » Freitag 27. Juni 2025, 10:52
Congratulations for this wonderful plugin !
It increases the features of SprintLayout by a huge margin, it is a must have plugin !
As we say in French: "Bravo" ...
