Hello,
The current maximum board size is 500x500mm. Some PCB manufacturers can handle up to 1200mm sizes. Is it possible to update SprintLayout so it will be possible do design lager panels?
I need to go to 750mm for now.
Best regards,
Rob
Max. board size
Re: Max. board size
OK, thanks. What will it be in the 7.0 version? Saw that is planned for 2027.
Re: Max. board size
No, this is not planned for the new version either, for technical reasons.
