no Grid in sPlan8.0
nounours18200
no Grid in sPlan8.0
Beitrag von nounours18200 »
Hello,
I cannot get the gris in sPlan 8.0 (up to date).
I have tried on a page with a formular, or on a page without formular, and it is the same: no grid.
See the parameters in the attached screen capture: I see nothing wrong..;
Thanks
ead66
Re: no Grid in sPlan8.0
Beitrag von ead66 »
wenn du das Blatt etwas herein zoomst, dann müsste das Raster zu sehen sein!
Viel Erfolg!
Hello,
if you zoom in a little on the sheet, you should be able to see the grid!
Good luck!
nounours18200
Oh sorry, so stupid !
Yes it works: with a stronger zoom, the grid appears....
Thank you.
