Problem with ctrl-c, ctrl-v after a short time
Bert01
Beitrag von Bert01 »
I have the latest update of Splan 8.0 installed (10/11/2021) but after a few minutes I can not copy and paste with ctrl-c & ctrl-v anymore. If I restart Splan it will work for a short time but then it stops again. What can this be?
I can do this from the drop down menu's but that is very annoying if you are used to the short cuts.
Bert
ps I am using Windows 10
Bert01
Re: Problem with ctrl-c, ctrl-v after a short time
I have found the reason for the problem with ctrl-c & ctrl-v. It is happening after I open and close the properties of a component. I don't have to change anything in the settings, just open and close the properties will make the ctrl-c & ctrl-v stop working.
This happens with my old libraries and with the new libraries supplied with splan 8.
I hope this helps.
Bert
Please install the latest update for sPlan 8.0. This should fix the problem.
Bert01
I did have the latest version but I did a reinstall to be sure. Then it is working fine but I noticed that the property window was different, I had it set to 'use dialogs instead of property-panel (old style)' in the general settings. I tried it and if I set this with my new install then the ctrl-c & ctrl-v is broken. When I turn it off, the ctrl-c & ctrl-v is working again, right away.
So just use the standard way, not the old style, for the properties and it is working fine!
Bert
Yes, I see. We will fix this in the next update.
Thanks for your info.
