Multiplexers in Profilab
Verfasst: Dienstag 30. September 2008, 11:05
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 16.01.2007 15:37 Titel: Multiplexers in Profilab
I use a 2 channel string multiplexer ,I am not sure what values should be on S0 to select $0 and what value on S0 to select $1.
at the moment I use a High on EN which selects $1 and a low on EN selects $0 .the application is working fine at the moment however I am not sure that I am using the multiplexer corectly.
Thank you very much
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
hrd
Anmeldungsdatum: 18.10.2006
Verfasst am: 16.01.2007 16:16 Titel:
EN: Enables multiplexer/output ($)
S0: lowest select address bit (0/1) (when 2 channels)
$0: Text with address 0
$1: Text with address 1
p.erasmus
Verfasst am: 16.01.2007 16:35 Titel:
hrd
Thank you for your advice!!
I will do it like you mention
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
Thank you very much
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
hrd
p.erasmus
hrd
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
