Front Panel to big
Verfasst: Dienstag 30. September 2008, 11:06
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 19.01.2007 21:07 Titel: Front Panel to big
Hello
I have made an application in Profilab it works well however when I make a exe file and install it on different PC`s and when the application is opened the Front panel are to large and only part of the indicators can beseen on the screen-
I am not sure about the properties of the frontpanel how do I ensure that the panel fit on all screen sizes and pixel reselutions
Thank you
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
Verfasst am: 22.01.2007 09:34 Titel:
You can try the "full screen" front panel property. Anyhow you´ll need to consider destination resolution for your design. Fixed resolution recommended.
p.erasmus
Verfasst am: 22.01.2007 19:32 Titel:
ll need to consider destination resolution for your design. Fixed resolution recommended.Zitat:
ABACOM Tanks for the reply
However this does not clear my problem ,How do I controll this resolution
if I know for instance that it will be used on a 1024 X 700 screen ,
or do I have to do the front panel then compile it run it on the destination PC if to bigg start again and make the panel smaller.
which is the correct way to control this in the design stage of the application.
Best Regards
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
Verfasst am: 24.01.2007 09:36 Titel:
You´ll need to design the FP small enough to fit the smallest resolution.
p.erasmus
Verfasst am: 24.01.2007 09:39 Titel:
Dear ABACOM.
Thank you this is what I though however I was not sure.
Best Regards
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
Hello
Thank you
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
p.erasmus
Best Regards
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
p.erasmus
Dear ABACOM.
Best Regards
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
