size of switches and buttons
Beitrag von abacom » Dienstag 30. September 2008, 11:05
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 16.01.2007 16:02 Titel: size of switches and buttons
Is it normal that it is not possible to increase the size of buttons and switches .
It would be nice if it is possible.
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
hrd
Anmeldungsdatum: 18.10.2006
Verfasst am: 16.01.2007 16:21 Titel:
As I know not but I haven't tried 'user-defined bitmap'. Maybe with that you can define your own size.
p.erasmus
Verfasst am: 16.01.2007 16:37 Titel:
I will read in the help file about user deifine bit map.
I hope it is possible.
Thanks for the reply
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
hrd
Verfasst am: 17.01.2007 10:40 Titel:
Just had a time slot and played with the bitmaps. That seems to work! You can zoom those bitmaps but you have to design your own buttons/switches.
p.erasmus
Verfasst am: 17.01.2007 19:25 Titel:
Hi hrd.
Thank you for your answer,I read about it in the help File however it only says that it is possible to increase the size not much documentation about it in the help file.
I am honest I have no idea to create the switches (where in what software) and how to create a bit map how do I do that.
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
hrd
Verfasst am: 17.01.2007 20:24 Titel:
If you have a switch in your project, go to the front panel, right click the switch and select properties.
In the representation select 'user-defined bitmap'. With that you will see a 'load bitmap for off status' and 'load bitmap for on status' below. There you have to load your bitmaps for off and on.
For a first start you can use Paint and draw something or write text for off and save it as bmp (do the same for on).
p.erasmus
Verfasst am: 17.01.2007 21:54 Titel:
Hi hrd.
Ok this now makes sense I have seen this in the front panel.
thank you very much for your help.
I wil try this on the weekend .
_________________
P.Erasmus
http://www.wenko.ch
Switzerland
