Problem with Y(t)-plotter
Denis
Beitrag von Denis » Mittwoch 21. April 2010, 10:55
Y(t)-plotter stops after 12 min.
Re: Problem with Y(t)-plotter
Beitrag von abacom » Donnerstag 22. April 2010, 09:21
Depends on sample rate. Number of samples is limited to approx. 30000.
KeesH
Beitrag von KeesH » Dienstag 4. November 2014, 11:36
LS,
Rather strange! The PLE-4 "Manual" indicates a maximum number of 16000 samples per channel that can recorded by the Y(t)-plotter. In the response above it states that approximately 30000 samples can be accomodated, but now in total (?).
From my experience with a 2-channel recording the latter (30000) seems to be correct.
Question to Abacom: it would be highly beneficial if the recording process would not be terminated if the maximum number is reached, but that it continues in a first-out last-in way, allowing a infinite recording process.
Abacoms ideas?
