Full screen mode
Maxiq4
Full screen mode
Beitrag von Maxiq4 » Freitag 24. Juli 2015, 18:35
Hi, when I choose full screen, right up corner X sign lost
Can I close profilab software other way? or easy anyway?
(without alt-F4)
regards
hrathke
Re: Full screen mode
Beitrag von hrathke » Freitag 24. Juli 2015, 21:20
Hi, there is a STOP function ....
regards
HR
Maxiq4
Beitrag von Maxiq4 » Sonntag 26. Juli 2015, 10:33
its work! thank you
may I ask a question too?
I have rs-232 re-connection problem
have any solution for it?
viewtopic.php?f=53&t=4197
thank you again
hrathke
Beitrag von hrathke » Sonntag 26. Juli 2015, 12:53
you can use a simple batch file...
close with STOP function and open the programm with START PROGRAM function over batch file again...
regards
HR
Maxiq4
Beitrag von Maxiq4 » Montag 27. Juli 2015, 08:18
Hr thank your answer but
I can well understand
did you explain some more pls
or if not diffucult could you add a simple example?
regards
hrathke
Beitrag von hrathke » Montag 27. Juli 2015, 19:09
ok, it works without a batch file too.
Start the main program "test" and hit the reconnect button. This close the main program and starts the reconnect program. This will be finish and starts the main program and so on....
regards
HR
PS: look for the paths and you have to compiled it first - otherwise it will not work!!!
reconnect.prj
(1.48 KiB) 508-mal heruntergeladen
test.prj
(1.15 KiB) 563-mal heruntergeladen
Maxiq4
Beitrag von Maxiq4 » Mittwoch 29. Juli 2015, 06:23
Fantastic idea, its done!
thank your help @hrathke
Im happy :D
