Jump indication when wires cross
windcrest77
Beitrag von windcrest77 » Dienstag 10. August 2021, 23:43
When two wires are crossing, SPlan is not adding the jump over symbol. Is there a setting that will make sure all crossed wires have the jump over (not connected) indication? I understand how to add the connection dot when you do want a connection. But how do I add the "not-connected" jump indication when I do not want a connection?
In the USA most schematics always indicate crossed wires as jumps (old school). I've attached an example in case I didnt ask the question well enough.
Note the wire cross indication, that is what I want to happen automatically.
e-bernd1954
Re: Jump indication when wires cross
Beitrag von e-bernd1954 » Mittwoch 11. August 2021, 06:01
SPlan is a simple drawing program, the program does not recognize line crossings, it is not e-routing
Chemnitzsurfer
Beitrag von Chemnitzsurfer » Donnerstag 19. August 2021, 20:42
You can also create the symbol manually and then insert it if necessary
1) create a broken line and a continuous line that crosses the first line
2) Use the Bezier curve function and create a curve/semicircle between the two parts of the broken line
3) mark the construction and create a new component from it and add it to a component library
4) If necessary, rotate the construction and also save it in the component library
e-bernd1954
Beitrag von e-bernd1954 » Donnerstag 19. August 2021, 21:12
yes, manually build symbols and then insert them accordingly
, is a guite solution
Greetings Bernd
