Picture import problem
SørenP
Beitrag von SørenP » Freitag 12. August 2022, 10:48
Hi.
I'm running sPlan8 on Win11. I took picture of a small PCB with my smartphone that I want to import to a drawing. But when I select the picture (jpg) sPlan shuts down. I have tried with other jpg pictures and there is no problem. What can I have done wrong with the jpg file? Is there any restrictions regarding the jpg format?
Re: Picture import problem
Beitrag von abacom » Montag 15. August 2022, 07:12
Hi what is the resolution of this jpg?
You may try to reduce the resolution in an external graphic app (like PAINT), save it and try again.
SørenP
Beitrag von SørenP » Dienstag 16. August 2022, 06:30
The size an res. of the picture is 400x560 pix and 72 dpi, so I don't think it's because it is too big :-)
SørenP
Beitrag von SørenP » Donnerstag 1. September 2022, 08:05
I may have found a solution to the shot down problem when importing pictures. I removed the EXIF data from the picture and the sPlan8 do no longer close. :-)
