French translation
devshibby
French translation
Beitrag von devshibby » Sonntag 27. Januar 2013, 12:09
Hi Abacom,
The "Joint tracks" function hasn't been translated into french:
Joint tracks: Fusionner les pistes
Tracks are joined: Les pistes ont été fusionnées
The "Strg"+something shortcut infos on the menus should be "Ctrl"+something.
When exporting the PCB to a picture for instance, with a high resolution, the following message appears:
"Vous êtes sur le point de créer une très grande image.
Il est préférable que votre travail soit ait été sauvegardé.
Continuer?"
I've added colors to show the typo, it's either "soit sauvegardé" or "ait été sauvegardé".
Furthermore, this message is not very clear about what's going to happen, will the file be saved before exporting it as a picture or not?
So, I think it would be better to also warn the user that he has to save the file prior to export it.
I suggest the following translation:
Il est préférable que votre travail soit sauvegardé au préalable.
Continuer tout de même?"
Re: French translation
Beitrag von abacom » Montag 28. Januar 2013, 12:36
Thanks for your hints.
We will add these translations to the next update.
The bitmap file will always be created.
In some rare cases it may happen, that this creation can take a long time or even fails, so this message is only a warning better to save your work first.
devshibby
Beitrag von devshibby » Samstag 9. Februar 2013, 13:56
I don't want to bother you, but the "Strg" shortcuts are still there:
Beitrag von abacom » Montag 11. Februar 2013, 11:16
Yes, I kwow.
But these texts are generated from our compiler itself, and unfortunately we can't change this text.
So, this is a thing we must live with.
devshibby
Beitrag von devshibby » Montag 11. Februar 2013, 13:17
Ok, it's not a big issue anyways.
