Problem exporting HPGL weird point added
noel
Beitrag von noel » Sonntag 21. August 2011, 19:26
Hello
i'm exporting layouts created with Sprint layout version 5.0.
When I export the print -> "Datei -> Exportieren -> Fräsdateien ->Isolationsfräsen (HPGL)"
I set the "zentrierkörnungen" to left bottom.
Everything is correct except it adds this:
Code: Alles auswählen
IN;
PT0;
PU;
PA-5,65;
PD;
PU;
PA348,2758;
PD;
Well PT0 is the zero point.. the PU is pin up then PA is pin absolute position minus 5 and 65..
That one is incorrect. The real point it should start at is PA348,2758...
I dont' have a clue why it adds PA-5,65...
and i'm wondering if anybody here has a clue why it does it and how to disable it..
I can add it to my program to remove it.. but i rather remove it at the source.
Friendly greetings from Belgium!
Re: Problem exporting HPGL weird point added
Beitrag von abacom » Montag 22. August 2011, 09:15
This seems to be a reference drilling. Do you have select a reference hole in the export dialog?
