MODBUS configuration IP as variable
dstorey
Beitrag von dstorey »
Hello
Does anyone know if it is possible to configure the modbus-tcp functions to take an IP address as a $string so I can set the IP address of my RTU's from the front panel?
It seems that they are hard-coded into the definition.
thanks Dominic Storey
Re: MODBUS configuration IP as variable
- Check the "run-time editable" box.
- Check "Configuration: Application" in front panel properties
- IP is now editable at run-time
- Click "screw-driver" button at run-time for that.
Sorry, but there is no $string input for that.
Zurück zu „Thema Modbus“
