Digital Control Default OFF Setting
QMESAR
Beitrag von QMESAR » Sonntag 26. Februar 2017, 17:23
Hi All,
Please help me understand I have various digital controls on my Front Panel the default is set to off
In my understanding from the help file the controls should be off when the program starts,however with me when a user leave a switch switched ON and then close the application
and then restart the application again the Button is the still ON which can cause some serious accidents on a system that it controls as the system starts up not to a defined state
Please help me to understand this behaviors and how to ensure when the user left a button ON and closed the application to ensure that all controls startup in the OFF state please see below
screen prints
Any help much appreciated
QMESAR
Re: Digital Control Default OFF Setting
Beitrag von QMESAR » Montag 27. Februar 2017, 18:17
Dear ABBACOM
Does any team member actually give support in the Forum ,This is my second question I asked regarding PL and nobody makes an effort to help ,
or should I use your email contact to ask for support,the question might seem silly to you however for me it is quite an important aspect to understand.
Or should I use google and translate the question into German?? I do not know something is wrong as nobody seems to bother to answer or help out
Where should we ask for help /support on your product??
Beitrag von Mike D » Dienstag 28. Februar 2017, 10:14
Hej,
in the properties of the front panel is a check box "remember last settings". This overwrites the default settings.
QMESAR
Beitrag von QMESAR » Dienstag 28. Februar 2017, 11:09
Dear Mike
Thank you very much for your help now it is clear and working Thank you again very much it is highly appreciated
Regards
QMESAR
