The way (Basics) to build one prohect with WEB SERVER
Verfasst: Dienstag 11. Oktober 2011, 13:44
von Stephane
I'd like to realize one project using WEB SERVER with my students (A simple one for the moment) :
Switch On a LIGHT via the internet and verify with an LDR sensor that the LIGHT is correctly on (I join the schematic diagram).
I'd like to present this project to a team of teachers to show them the possibilities of PROFILAB EXPERT and WEB SERVER.
I'd like to realize a complete pedagogic ans ressources file to help teachers.
I realized (basic) my local application.. no problem in a local configuration (I join my program)
But I don't know how to go on to transfer my application to another computer ..
HELP needed........
thanks
Stephane
Re: The way (Basics) to build one prohect with WEB SERVER
Verfasst: Mittwoch 12. Oktober 2011, 08:22
HELP needed........
What do you mean? Please be more precise!
Did you step through the manual?
PLWebserver10_Manual.pdf
(333.73 KiB) 1151-mal heruntergeladen
Re: The way (Basics) to build one proJect with WEB SERVER
Verfasst: Mittwoch 12. Oktober 2011, 09:26
von Stephane
Bonjour
I'm there in front of my 2 computers :
the one with PROFILAB and WEB SERVER
the other one with my browser (Firefox).
I realized my project on the : no problem, ... of course, too much simple..
Now ? How can I realize the connection between the 2 computers ?
In fact, what is the next step ?
There's no documentation on the operating mode...
Thanks
Verfasst: Mittwoch 12. Oktober 2011, 09:46
Did you step through the manual? :!: :?:
Make sure Webserver/Project is running and published (in Front panel properties).
Local: type "127.0.0.1" in Webbrowser
Lan: type <Server-IP> in Webbrowser
Web: type <Server-URL> in Webbrowser
??? What do you mean ???
establish a connection
Verfasst: Donnerstag 13. Oktober 2011, 17:05
von irrerpolterer
Hallo et bon jour du tout!
I think we can't know exactly if there is a running ethernet connection at all. Try to ping Your computers first (C:\ping 192.168.1.209 and press <<<enter>>> for example). Do You have dhcp enabled or not? Is there a switch, hub or router connected to Your pcs? Otherwise xlink cable? How does Your browser connect to the web or so?
A bientôt et Grüße
