Hello Team.
I am using Profilab for a few years and did many project with micro controllers and Profilab interfaces to the mcu's over serial port and now using an FTDI USB translator chip and serial,
However I am designing a new PLC controller which uses a PLC board with an Ethernet interface as shown in the attached photo and I would like to ask some information about PL4.0
(1) is it possible to use the PL4.0 TCP block to interface PL to my mcu in UDP
(2) what possibilities does PL have to do such a connection
(3) any idea how I can use PL with this Ethernet port on the PLC board
I appreciate any help or comments
Best Regards
Peter
TCP-IP and Profilab
TCP-IP and Profilab
- 2.PNG (199.78 KiB) 6317 mal betrachtet
Re: TCP-IP and Profilab
The way to go is to use a piece of external software - a virtual ethernet com port -
like this one, for example:
http://www.hw-group.com/products/hw_vsp/index_en.html
I use it all the time in connection with Profilab and LAN DMMs, LAN scopes and LAN PSUs and LAN what not.
Just search the Profilab Expert forum for SCPI, for some examples.
Yours Messtechniker
Yours Messtechniker
Dear MesstechnikerThe way to go is to use a piece of external software - a virtual ethernet com port -
Thank you very much for your help It is really appreciated
Have a wonderful Christmas time and new year
Peter
Zuletzt geändert von QMESAR am Samstag 24. Dezember 2016, 08:21, insgesamt 1-mal geändert.
Dear Messtechniker.I use it all the time in connection with Profilab and LAN DMMs, LAN scopes and LAN PSUs and LAN what not.
I am very new to this topic and appreciate all help I get,
reading from the link you posted it is not clear to me does this driver needs to be installed on the machine that runs PL4.0 program and does it run in the backgroud
secondly do you need to start this driver every time you run your PL SW or does it automatically start when the PC boots up
many thanks for sharing your experiences
Regards
Peter
The virtual LAN COM port software/driver needs to be installed on the PC running Profilab and it runs in the background
You then access this new COM port though a COM component of Profilab set up accordingly (Port, Baud Rate etc.)
The virtual LAN software/driver can be made to start up automatically once it has been set up.
Finding the necessary LAN TCP/UDP port data and settings of your target unit can be a bit difficult
as these are often not prominently or not mentioned at all in the documentation.
Yours Messtechniker
Yours Messtechniker
Thank you very much for sharing the information much appreciated Messtechniker
Regards
Peter
![Smile :)](./images/smilies/icon_e_smile.gif)
Regards
Peter
