[Solved] How can I remove a part (only) of th Ground plane ?
Verfasst: Dienstag 7. März 2023, 15:26
von nounours18200
I know that it is possible but I don't remind how...
I would like to remove just a part of the ground plane, or define an area in which there is no ground plane : look at the attached photo.
How can I achieve that ?
Thank you veyr much,
supprimer partie plan de masse_En_M.jpg (89.99 KiB) 6531 mal betrachtet
Re: How can I remove a part (only) of th Ground plane ?
Verfasst: Dienstag 7. März 2023, 16:30
von HAL90009
At the bottom, where the auto mass is activated, there are two icons for rectangle and polygon. With these you can draw blocking areas for the automass at the desired position.
Verfasst: Dienstag 7. März 2023, 17:45
von nounours18200
Thank you very much Hal90009: this is exactly what I was looking for !
