Picture import problem
SørenP
Beitrag von SørenP »
Hi.
I'm running sPlan8 on Win11. I took picture of a small PCB with my smartphone that I want to import to a drawing. But when I select the picture (jpg) sPlan shuts down. I have tried with other jpg pictures and there is no problem. What can I have done wrong with the jpg file? Is there any restrictions regarding the jpg format?
Re: Picture import problem
Hi what is the resolution of this jpg?
You may try to reduce the resolution in an external graphic app (like PAINT), save it and try again.
SørenP
The size an res. of the picture is 400x560 pix and 72 dpi, so I don't think it's because it is too big :-)
SørenP
I may have found a solution to the shot down problem when importing pictures. I removed the EXIF data from the picture and the sPlan8 do no longer close. :-)
