Hello ,
I'm trying to built ,an automatic program in Prflab ,for a bluetooth module.
When the module acknowledge the good protocol of command, it transmit a string "OK"
I 'm arrived to display this string ,but not compare.
I used string comparator with OK in channel A ,and string from port com receive.
I am not arrive to detect this "OK" string
Thank for people ,who can help me
Here, pictures of my problem
String comparator ,problem
- Ascii display.PNG (1.3 KiB) 14741 mal betrachtet
- String display.PNG (3.95 KiB) 14742 mal betrachtet
- String comparator.PNG (14.17 KiB) 14730 mal betrachtet
Re: String comparator ,problem
Hello TOURNEUR,
you might have to put a '$TRIM' in between the 'Selection' & the '$COMP' parts, as in the picture below. (removes any unwanted SPACES from String)
As an alternative check it out with a '$CONST' instead of 'Selection' ...
- PL-E_$TRIM.png (12.89 KiB) 14718 mal betrachtet
Good evening , IKT
Thank you for your help ,
I inserted this function between my Hex generator and comparator.
Without any success ...
I have put command on left and right, but nothing more .
Hello,
may be that there are CR LF at the end of the string, coming form the device?
LG Wolfgang
LG Wolfgang
Hei,
try $Position instead of $Comp, then leading or trailing unvisible chars dont bother.
Any number greater than zero means, that $S exist in $M.
If you position the cursor on a connection during the projekt is running, you can see the actual value of the singnal.
