Full screen mode
Verfasst: Freitag 24. Juli 2015, 18:35
von Maxiq4
Hi, when I choose full screen, right up corner X sign lost
Can I close profilab software other way? or easy anyway?
(without alt-F4)
regards
Re: Full screen mode
Verfasst: Freitag 24. Juli 2015, 21:20
von hrathke
Hi, there is a STOP function ....
regards
HR
Verfasst: Sonntag 26. Juli 2015, 10:33
von Maxiq4
its work! thank you
may I ask a question too?
I have rs-232 re-connection problem
have any solution for it?
viewtopic.php?f=53&t=4197
thank you again
Verfasst: Sonntag 26. Juli 2015, 12:53
von hrathke
you can use a simple batch file...
close with STOP function and open the programm with START PROGRAM function over batch file again...
regards
HR
Verfasst: Montag 27. Juli 2015, 08:18
von Maxiq4
Hr thank your answer but
I can well understand
did you explain some more pls
or if not diffucult could you add a simple example?
regards
Verfasst: Montag 27. Juli 2015, 19:09
von hrathke
ok, it works without a batch file too.
Start the main program "test" and hit the reconnect button. This close the main program and starts the reconnect program. This will be finish and starts the main program and so on....
regards
HR
PS: look for the paths and you have to compiled it first - otherwise it will not work!!!
Verfasst: Mittwoch 29. Juli 2015, 06:23
von Maxiq4
Fantastic idea, its done!
thank your help @hrathke
Im happy :D
