[Solved] How can I remove a part (only) of th Ground plane ?
nounours18200
Beitrag von nounours18200 » Dienstag 7. März 2023, 15:26
I know that it is possible but I don't remind how...
I would like to remove just a part of the ground plane, or define an area in which there is no ground plane : look at the attached photo.
How can I achieve that ?
Thank you veyr much,
supprimer partie plan de masse_En_M.jpg (89.99 KiB) 4269 mal betrachtet
Zuletzt geändert von nounours18200 am Dienstag 7. März 2023, 17:45, insgesamt 1-mal geändert.
HAL90009
Re: How can I remove a part (only) of th Ground plane ?
Beitrag von HAL90009 » Dienstag 7. März 2023, 16:30
At the bottom, where the auto mass is activated, there are two icons for rectangle and polygon. With these you can draw blocking areas for the automass at the desired position.
nounours18200
Beitrag von nounours18200 » Dienstag 7. März 2023, 17:45
Thank you very much Hal90009: this is exactly what I was looking for !
