[solved] Footprint: 72 pins, 10x10mm, LFCSP package
nounours18200
Beitrag von nounours18200 » Freitag 4. November 2022, 11:40
I am looking for the following footprint:
72 pins, 10x10mm, LFCSP package, maybe its normalized name is "CP-72-6", as described in the attached screen capture:
footprint LFCSP CP-72-6.JPG (104.68 KiB) 3452 mal betrachtet
It is the footprint of an analog Device DSP named: adau 1466.
Does any of you have this footprint ?
Thank you very much,
Zuletzt geändert von nounours18200 am Montag 7. November 2022, 10:51, insgesamt 1-mal geändert.
nounours18200
Re: Footprint: 72 pins, 10x10mm, LFCSP package
Beitrag von nounours18200 » Montag 7. November 2022, 10:50
I have found a solution: you just have to install the Sprint Layout plugin named "Sprintfoot" that allows to import any footprint from Kicad.
This plugin is a "must have" plugin, giving access to the huge library of footprints from Kicad !
