I use sPlan 8.0 and I suggest an improvement that is probably easy to implement in a future update:
I would like to have " Copy full Path+Name" function from the Edit Menu, in order to quickly paste it in a Text field of the schematic: this helps to find the file when we just have the printout.
This would be similar to what already exists in Notepad++.
I had explained that in an old topic here: viewtopic.php?f=11&t=5908
By the way, this would benefit to Sprint Layout too...
A "nice to have feature" ...
Future Splan 8 update: Full Path+Name
Re: Future Splan 8 update: Full Path+Name
May be you can use the following functions in a text box:<FILEPATH><FILENAME>?nounours18200 hat geschrieben: ↑Samstag 29. Juni 2024, 10:50I would like to have " Copy full Path+Name" function from the Edit Menu, in order to quickly paste it in a Text field of the schematic: this helps to find the file when we just have the printout.
These are two fixed variables (<FILEPATH>, <FILENAME>) and you will find them under the button 'insert fixed variable'. You can write them one after another without any space.
Hardy
Windows10 Home/V. 22H2
sPlan 8.0
Hardy
sPlan 8.0
These are two fixed variables (<FILEPATH> and <FILENAME>) and you will find them under the button 'insert fixed variable'. You can write them one after another without any space.
But it will be very beneficial, if you can choose at the insertion between the real words of the text box (e.g. "<FILEPATH><FILENAME>") or the content of the fixed variables (e.g. "D:\sPlan\projects\filename.spl8").
Zuletzt geändert von Hardy am Dienstag 2. Juli 2024, 19:58, insgesamt 1-mal geändert.
Hardy
sPlan 8.0
Hardy
sPlan 8.0
Thank you VERY much Hardy: it is a perfect solution !
I am also looking for a similar function with Sprint Layout, in order too have the full "Pathname+Filepath" close to the PCB design: do you know a similar solution on Sprint Layout ??
Thank you
Thank you
I do not have Sprint Layout. So, I can't help you with this program. But did you start a thread in the part of the forum for Sprint Layout with this question?nounours18200 hat geschrieben: ↑Dienstag 2. Juli 2024, 18:47I am also looking for a similar function with Sprint Layout, in order too have the full "Pathname+Filepath" close to the PCB design: do you know a similar solution on Sprint Layout ??
Hardy
sPlan 8.0
Hardy
sPlan 8.0
I didn't but I going to start a topic.
Thank you very much for
