Request for some improvements
Ster4Eko
Beitrag von Ster4Eko » Donnerstag 23. Mai 2024, 08:51
Hello, dear Abacom and dear users.
I have been using sPlan for several years, I create quite advanced projects with this program and I would like to ask for a few improvements that will make my work easier (perhaps also for other users):
1. Please create a new fixed variable: <PAGE_DESCRIPTION>, it will be useful in forms
Bildhttps://zapodaj.net/plik-Ct8IJoQzvo
2. I would like to be able to highlight project page tabs in color - as in the figure below. When working many hours with a project that is over 40 pages long, you can get lost.
Bildhttps://zapodaj.net/plik-4jjcwojM6P
3. When I use TextRect and use the right shortcut Alt+A (I want to insert the Polish letter "ą") - the entered text disappears and is replaced with the letter "ą" - the text should not disappear. I can enter other Polish characters using the right shortcut Alt+e which gives the letter "ę", Alt+z which gives "ż" and everything works correctly except Alt+a - the previously entered text disappears.
4. Please introduce the possibility of switching the text position when dimensioning. In a horizontal drawing, the dimension text is on the left. After printing the text and placing the paper vertically, the text is upside down
Bildhttps://zapodaj.net/plik-8t7HH5w3Jd
Regards
Ster4eko
Re: Request for some improvements
Beitrag von abacom » Donnerstag 23. Mai 2024, 14:32
Thanks for your suggestions.
Here a few remarks:
This will not be possible because a variable in sPlan can only be 1 line, and a desription can have as many lines you want.
3. When I use TextRect and use the right shortcut Alt+A (I want to insert the Polish letter "ą") - the entered text disappears and is replaced with the letter "ą"...
"AltGr+A" seems to be a windows-hotkey in the edit box which selects the old text (select all) and the selected text will then be deleted if inserting a new character. You may use the hotkey CTRL-INSERT to call the "special-character-dialog" from sPlan instead.
I don't get it. What exacxtly is here the problem? If you rotate the whole page 90° anti clockwise, all texts will be also rotated, and so also the dimension texts.
