alternative USB ADC for use in profilab
Nick Twyford
Beitrag von Nick Twyford »
I wondered if there was an alternative usb analogue digital converter that is configurable with Profilab. This is the one we are looking for an equivelant for;
http://www.electronic-software-shop.com ... 095-v.html
Any help would be much appreciated,
Many thanks,
Nickie Twyford
Re: alternative USB ADC for use in profilab
Beitrag von IKT »
@Nick T,
a little bit additional information whould not hurt at all:
- why do you need the replacement?
- are there other analog Voltage ranges needed? (0-10VDC)
- lower/higher precision e. g. 8, 10, 14 or 16 bit's?
- is it the price?
- additional digital channels?
Well, Redlab, LabJack, Modbus devices, DVM, (...)
What is the intention of this request?
http://www.abacom-online.de/div/hardware_uk.pdf
Nick Twyford
we are just looking at alternatives within the company if the ABACOM board ever needed replacing. We have another board on order however one has been lost in transit so may require an alternative for our test system. There a 3 devices running from the board and we are more than happy with running the system using a 16 Bit device
Beitrag von IKT »
@Nick T,
sorry, but there is a small correction needed:
ADC - ABACOM - as in Spec's. = 0 - 4.095 Volts = 1mV Step = 12 bit ...
Well, we still got enough for sale, just in case you´d like to stock some for replacement. ;-)
Zurück zu „Thema Hardware-Beispiele / Examples“
