PI Controller Reset function
QMESAR
Beitrag von QMESAR » Montag 27. März 2017, 15:18
Hi All,
Please I need your help with the PI Controller,As shown in the attached sketch I have my set point signal and the feed back signal with the KP and KI parts the output goes into a limiter that sets me the max and minimum outputs for the controller.
This functions however my problem is how to reset the integrator ,my understanding from the help file is the reset pin reset the integrator and by adding a pulse generator to the RST pin with a rate at 1 sec I can see the output go higher and at 1 second fall back to the original value however in the real system this is a problem as the actuator would move to try and correct the error but when the integrator is resetted it falls back even with not correcting the error,I need the actuator to keep on moving to correct the error until max is reached and then stay there if the error remains or when the error get smaller and even 0 then the integrator should reset,
How can I achieve this in PL I appreciate all help highly
Kind Regards
Re: PI Controller Reset function
Beitrag von abacom » Dienstag 28. März 2017, 08:06
Simply pull down /RST to LOW once for reset, whenever necessary. That´s it.
QMESAR
Beitrag von QMESAR » Dienstag 28. März 2017, 10:33
abacom hat geschrieben:Simply pull down /RST to LOW once for reset, whenever necessary. That´s it.
Thank you for the reply , :D
This is not my problem how to reset it, I have done that by pulling the RST pin low and it works my question was how can I determine when the error is small and the integration should stop or be set to zero ,Do I calculate the error manually in front of the PI component with a math component ?
Beitrag von abacom » Mittwoch 29. März 2017, 08:18
??? So I don´t understand your request unfortunately. Sorry for that.
tmm
Beitrag von tmm » Mittwoch 29. März 2017, 08:35
for example, do something like this........
integration_only.prj
(810 Bytes) 861-mal heruntergeladen
Beitrag von Mike D » Mittwoch 29. März 2017, 08:51
since you use the limiter, have you already seen the properties of PI?
Make a double klick on PI.
P.S. please use punctuation marks and shorter sentences. So we could better understand you.
QMESAR
Beitrag von QMESAR » Freitag 31. März 2017, 11:39
Hi All.
tmm thank you for your PL project this helped me to do as per attached screen print,maybe not perfectly correct but it functions in real time operation and I can live with it for now on the machine
All that I asked was
(1)ideas for a method to determine when the error is small;this method should the reset / stop the integration of the PI or PID component
(2) It was clear that pulling the RST pin low the integration will stop or reset (This is clearly mentioned in the Help file)
(3) I do read the help file before wasting peoples time here in the forum
