I ask you to help to create a running sum with a dll.
You tell me what to do?
I need to learn how to test.
thanks
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.IO;
namespace Somma
public class Somma
public static class Somma
public static int Somma(int a, int b)
return a + b;
Somma dll
Re: Somma dll
Place the right code, I hope someone can help.
Hi
void NumInputs()
return 2;
void NumOutputs()
return 3;
void GetInputName(uchar Channel, uchar *Name)
switch(Channel)
case 0: strcpy((uchar *)Name, "Num1"); break;
case 1: strcpy((uchar *)Name, "Num2"); break;
void GetOutputName(uchar Channel, uchar *Name)
switch(Channel)
case 0: strcpy((uchar *)Name, "Add"); break;
case 1: strcpy((uchar *)Name, "Sub"); break;
case 2: strcpy((uchar *)Name, "Mul"); break;
void CCalculate(double *PInput, double *POutput, double *PUser)
POutput[0] = PInput[0] + PInput[1]; // add
POutput[1] = PInput[0] - PInput[1]; // subtract
POutput[2] = PInput[0] * PInput[1]; // multiply
Hi
void NumInputs()
return 2;
void NumOutputs()
return 3;
switch(Channel)
switch(Channel)
Re: Somma dll
thanks WoB
