simulation frequency
Beitrag von abacom » Montag 13. Oktober 2008, 11:17
p.erasmus
Anmeldungsdatum: 15.01.2007
Verfasst am: 10.06.2007 09:47 Titel: simulation frequency
In my application the Simulation frequency shows 38.5Khz does this mean that all the code in the application is executed 38.5K times
or could you please explain to me te relevance of this figure and will the speed be the same when the application run in real time stand alone or would the speed increase or decrease
Thank you very much
Peter
_________________
P.Erasmus
Automotive Engineering
http://www.wenko.ch
Switzerland
hrd
Anmeldungsdatum: 18.10.2006
Verfasst am: 11.06.2007 07:19 Titel:
Yes, the code runs 38,5 kHz through every second. If you run it in real time on the same computer (compiled) it will run in the same speed. I think you can choose Fast or Low with compiled projects as well (set before compiling).
p.erasmus
Verfasst am: 11.06.2007 08:00 Titel:
hrd
Thank you for your reply
it is clear now and yes I use the slow mode for debuging and the fast mode for real tome operation
Best Regards
Peter
Zurück zu „Thema: Geschwindigkeit und Systemauslastung“
