sorry if the topic name is a bit unclear.
I've saved a layout. when i reopen it all the components are now "1" component. I can't split them because they don't seem to be in a group. I can however select a single line by selecting it and holding the alt key.
So what i'm asking is is this a bug or a feature, if its a feature is it possible to split them...? so it was when i saved it ?
If needed i can supply a .lay6 file.
Friendly greetings
Noël
Stored layout has become one item
Re: Problem stored lay is 1 item
did you save the file with the "disc"-Symbol (save/save as...) or did you save it "as a makro" (that means you added it to the your library of your components as a component)?
In the latter case everything is locked together as one part. If you select all (everything is highlighted then) an then click the "unlock" button (the unlocked padlock symbol) the details will be separated again. But use this command only one time - otherwise each component would be separated also.
kind regards
Bernd
kind regards
Bernd
Re: Stored layout has become one item
Guten Morgen + vielen Dank! Bereits Lesen hilft.
Zu deutsch: es handelt sich um das "Vorhängeschloß"-Symbol mit dem Kontext: Gruppierung aufheben.
