A plugin for Sprint-Layout, Import footprint from Kicad/EasyEDA
cdhigh
Re: A plugin for Sprint-Layout, Import footprint from Kicad/EasyEDA
Beitrag von cdhigh » Freitag 19. August 2022, 15:34
I scaned the 3 qrcode images you generated, the results correct.
K-B-L
Beitrag von K-B-L » Freitag 19. August 2022, 15:57
but why it looks different?
my Iphone can only scan the black one. Not the QR in Sprint Layout
cdhigh
Beitrag von cdhigh » Freitag 19. August 2022, 16:45
The qrcode feature of IPhone camera is not very smart (less tolerance).
I tested with iPhone.
Found that iPhone can recognized both 2 images If I increased the grid size of Sprint-Layout to 5.08mm.
There are many parameters for QR code generation, and different parameters will produce different images, but all of them are valid.
For example, all of 4 images follows are generated from a same text string, but with the different error correction levels.
K-B-L
Beitrag von K-B-L » Freitag 19. August 2022, 17:04
ok thx for info
nounours18200
Beitrag von nounours18200 » Freitag 4. November 2022, 19:54
@cdhigh:
I will test the advanced features later, but for the time being I have just imported a few SMD footprints from Kicad, and your plugin is excellent !!
A must-have plugin: congratulations !!
CD32Freak
Beitrag von CD32Freak » Dienstag 21. November 2023, 20:01
Amazing plugin, you've implemented the features that were really missing in Sprint Layout! Thanks for sharing, cdhigh!
