SOIC/TSSOP 28 Footprint
nounours18200
Beitrag von nounours18200 » Mittwoch 11. Mai 2022, 20:35
Hello,
I am looking for the TSSOP-28 makro (for a Crystal CS8416 integrated circuit), but more generally a collection of TSSOP footprints would be appreciated !
I am sure that other persons before me have already done these footprints..
Do you know where I could find them ?
Thanks you very much
nounours18200
Re: SOIC/TSSOP 28 Footprint
Beitrag von nounours18200 » Donnerstag 12. Mai 2022, 16:06
UP
Nobody has TSSOP ready to use Makros ?
Sonny1983
Beitrag von Sonny1983 » Samstag 14. Mai 2022, 00:49
I don't have a macro for that, but the footprint should be available in the datasheet. Then you can use the "footprint assistent" / "macro assistent" (don't know the exact name of the function in english; you find it in the upper menu under "extras"). With the assistent you make the smd footprint. After that, you just have to make a rectangle on the silkscreen layer with the outline dimensions (use a small grid, like 0,1mm). Mark both the smd pads (grouped) and the rectangle and center them horizontally and vertically ("align" function). Add a marking for pin 1, group everything, make it a macro (context menu) ans you're done.
If the datasheet of the particular part doesn't have a footprint, just use another part with the same footprint (search on digikey/mouser/... in "ICs" and filter by package) and look in it's datasheet.
nounours18200
Beitrag von nounours18200 » Samstag 14. Mai 2022, 12:06
OK: meantime I have found the footprint ,
Thank you very much,
