Leave blank around the pad without using Ground plane
burhan
Beitrag von burhan » Donnerstag 23. September 2021, 17:25
Hello,
How can I do that?
Re: Leave blank around the pad without using Ground plane
Beitrag von abacom » Freitag 24. September 2021, 08:32
If you place a pad on the "automatic-Ground plane" it will have a clearance to the groundplane.
The width of this clearance can be set in the lower statusbar. You can change this value if nothing is selected, then it will be the new default value for all new elements. Or you can select a pad and then change this value only for this selected pad.
K.Achim
Beitrag von K.Achim » Freitag 24. September 2021, 09:35
...and if you want pads without holes, just reduce inner diameter to zero...
SPlan 8.0, SPlan 7.0
Lochmaster 4.0
SprintLayout 6.0
burhan
Beitrag von burhan » Samstag 25. September 2021, 17:43
Hello,
I solved the problem with "zone" (without ground plane). Thanks everyone
