S2 solder mask
PeepoUK
S2 solder mask
Beitrag von PeepoUK » Dienstag 11. September 2018, 09:32
Hello all, I am new to this product but I have already got the hang of it as it's quite intuitive.
I've recreated a board that was damaged by tracing over scans of the original board. All is good except for when I try and place soldermask on the lower side of the board.
On the upper side of the board I selected zones and then select "Only Soldermask" in the properties. This worked fine and shaded the area with diagonal lines.
When I do the same on the lower side of the board I get a solid yellow zone and nothing happens when I select "Only Soldermask" in properties. When I go back in to the properties the checkbox is unchecked again.
Any help would be appreciated. Thank you!
PeepoUK
Re: S2 solder mask
Beitrag von PeepoUK » Dienstag 11. September 2018, 10:34
It's OK.
I was setting soldermask on the Silkscreen layer 2 instead of copper layer 2. Doh! :lol:
All sorted now.
