Hello
I need to save a file on the disk but the file name is assigned automatically when I press a button.
example: when I press the button excel, the file should be saved automatically without thinking to enter the name of the file.
The name of the file should add it automatically.
thanks
Save automatically
Save automatically
- 2014-03-05_234111.jpg (67.31 KiB) 7157 mal betrachtet
Re: Save automatically
Hello Millman,
if I understand you correctly, you want to do the following:
- send (PL)Table Data to Excel (using HotKey feature)
- then save the Excel file without giving it a NAME
If above assumption ist correct then:
- send ... -- is not a problem, at all
- then save ... -- is not a problem of PL, rather an Excel problem (or any other called application, for that matter), this means you are in the wrong forum to get this issue resolved. Try a Microsoft Office forum for assistance.
