Hi all,
We are some friends who love electronics and education.
To learn possibilities ProfiLab we like to try full control one old Washing Machine using PC and ProfiLab.
Project start with not clearly final plan, but in short:
1. Remove totally control mechanism and connect all to one I/O board with microcontroller.
2. Board initial connected to PC via RS485 (next step via Bluetooth and why not via TCP/IP...)
3. Add to Washing Machine some additional sensors like temperature sensors, tachometer, remote control …
4. Any more ideas welcome…
Initial equipment:
1. ProfiLab Expert
2. PC Celeron 3.33GHz, 2GB RAM.
3. Washing Machine ‘Ariston Margherita’ (bought from friends who import used technique for 25.00 EUR)
4. USB<>RS485 converter and RS485 I/O board with 8+8 Inputs and 8 relays)
Until now we remove controller, found scheme (not exactly for this model but …) and build simple test PL application.
We will share photos and projects.
Hope this project helps us and people to learn ProfiLab.
Thanks to:
- Mr. Lothar Feldmann and Mr. Matthias Prüssel from Abacom for copy of software.
- KAKTUS from forum for help build first test application
Project is for fun and education so any help and suggestions are welcome…
Motor Speed controller
Interface
Test Aplication
Regards
Control Washing Machine using ProfiLab
- Washing_IO_Test_v1.4.prj
- (39.36 KiB) 469-mal heruntergeladen
Re: Control Washing Machine using ProfiLab
That's a very nice project !!!!
Where is the first malt distillery in PL ?
Blupf
Blupf
Thanks Blupf!
After two days troubles how to connect motor and speed controller we have ready first version of hardware.
Is not connected to PC, but simple test works - on/off water pump, rotate left/right with different speeds.
Now we start PL application ....
Small video and some photos:
http://www.youtube.com/watch?v=Xs9Rym5uvGE
Great Application !!!
in german language: miele miele sprach die Tante, die alle Waschmaschinen kannte
please let us know if you have any other applications, like this.
thank U
Thomas
thank U
Thomas
I have build a Fog maschine with PL and a Velleman k8055 and a power regulator.
It works nice and you cam make Fog for mor then 30 min.
I have no Picturees now but the Project file i can give to all.
best regates Tüftler
- Nebelmaschine neu.prj
- Fog maschine
- (53.89 KiB) 469-mal heruntergeladen
