willing to pay to create a module for serial rfid unit
aii
Beitrag von aii » Donnerstag 4. September 2014, 10:44
Hi all I need some help please. I am located in Melbourne Australia and I need to interface a serial rfid reader /writer into profilab. If anyone is interested in this project please PM me and I will send you a pdf with all the detail Thankyou.
Re: willing to pay to create a module for serial rfid unit
Beitrag von IKT » Donnerstag 4. September 2014, 12:16
Hi aii,
PM on it's way ...
cvr
Beitrag von cvr » Mittwoch 15. Oktober 2014, 09:34
I also need your support to develop a test setup
Zuletzt geändert von cvr am Donnerstag 16. Oktober 2014, 14:07, insgesamt 1-mal geändert.
Beitrag von IKT » Mittwoch 15. Oktober 2014, 10:24
Hi cvr,
I'm not willing to use any gmail and/or hotmail accounts, to do business with ...
Secondly some more technical information whoudn't hurt either.
cvr
Beitrag von cvr » Mittwoch 15. Oktober 2014, 11:59
IKT hat geschrieben:Hi cvr,
Ok here are the attachments
Beitrag von IKT » Mittwoch 15. Oktober 2014, 12:31
cvr hat geschrieben:Ok here are the attachments
no attachments ... try again!
Below the buttons ... (as in PM)
- click "Browse", select the file(s) to upload ("no files selected", must change to "your file(s)" )
- add "file description" in the empty space (only if you want/need to).
- click "Datei hinzufügen" to upload the file ... (the attachment file(s) )
- use "Vorschau" to check it (preview), and then (if everything appears OK)
- click "Absenden" to post it all, finished.
cvr
Beitrag von cvr » Mittwoch 15. Oktober 2014, 14:03
sorry here it is
cvr
Beitrag von cvr » Mittwoch 15. Oktober 2014, 14:23
ok the file sizes are 500kb and i cannot reduce it to 256KB
Zuletzt geändert von cvr am Donnerstag 16. Oktober 2014, 14:08, insgesamt 1-mal geändert.
Beitrag von IKT » Mittwoch 15. Oktober 2014, 15:24
Having had a look at your files, there are some mayor issues:
- does the RIGOL (Model ???, Manuals etc.) have a direct connection to PC (RS232/USB etc.)
- the "unit under test" ... what is it for, does it have to be connected too? how?
- you seem to be using lots of relays to achive digital switching ... why not do it digital by employing GATES?
Tip: if you do your Doc's in a spreadsheet, you'll not have any size problems to upload (as *.zip), as opposed to scans of handwritten notes ... (and they are far easyer to read by anyone). Rudimentary Graphics can also be done (or imported) by most of them (e.g. Libre-Office, free of charge), make shure to use "open doc" standard files (or MS-Office) if you have it.
Another few important things:
Who are you? Where from? You can PM me those things ... I'd like to know with whom I'm dealing.
Do you need a module or a complete application? How much Budget do you have allocated? Any additional info will speed things up ...
cvr
Beitrag von cvr » Mittwoch 15. Oktober 2014, 19:08
IKT hat geschrieben:Having had a look at your files, there are some mayor issues:
1. Yes Rigol DM3058e has USB ,RS232C -- is a multimeter
Zuletzt geändert von cvr am Donnerstag 16. Oktober 2014, 14:09, insgesamt 1-mal geändert.
Beitrag von IKT » Mittwoch 15. Oktober 2014, 20:15
There seems to be a massive misunderstanding here.
This thread says: Client specific Job-Offers around ProfiLab (which Abacom itself is NOT doing/offering)
I'm a ProfiLab-Expert Programmer and NOT Abacom (who sells the Programs and Hardware). I'm offering programming services and (if needed) Project-Management know-how only.
I think you should be able to buy the required SW/HW locally at some Distributor (mainly those, distributing Electronics for similar purposes). If this should not be the case, go to the Webshop of Abacom and place your Order there (you may have to have a Credit-Card for that).
http://www.electronic-software-shop.com/
cvr
Beitrag von cvr » Donnerstag 16. Oktober 2014, 02:14
ok understood
please send me your programming and recommended ABACOM hardware and software to buy directly from ABACOM
cvr
Beitrag von cvr » Donnerstag 16. Oktober 2014, 02:16
44
Zuletzt geändert von cvr am Donnerstag 16. Oktober 2014, 14:10, insgesamt 1-mal geändert.
Beitrag von IKT » Donnerstag 16. Oktober 2014, 09:27
@cvr,
I'll send you a PM ...
Zurück zu „Kundenspezifische Jobangebote rund um ProfiLab“
